820-02536 liquid damage 5V 0A
ajdoc
Heavy liquid damage on multiple areas.
PPBUS_AON on F5200 0.46V (0.495 in diode mode).
F5200 has been lifted for more tests.
LDOs of 3x CD3217 in diode mode are correct but PP3V3_S2_LDO have only 0.01V.
U5200 voltages:
P_IN 5.15V
AUX_DET 0.52V
SMC_RST_IN 0V
VDDA 4.46V
VDDP 4.46V
AUX_OK 0V
AMON 0V
BMON 0V
Any idea?
"AUX_DET 0.52V"
Should be 1.2V aprox, for 5V input.
"F5200 has been lifted"
Still no voltage at C5252?
Remove Q5216 and test again.
ajdoc
"Still no voltage at C5252?"
Still no voltage
Without Q5216 AUX_DET have 0.16V (0.582 in diode mode)
ajdoc
R5215 replaced (was in bad shape) and have now 0.85V.
R5216 looks good and have correct resistance.
Replaced U5200 as well and still 0.85V
Put back Q5216 and check if AUX_DET maintain its level.
Check resistance (ohm scale) over C5220/60.
Also check the values of all adjacent components and traces continuity.
