820-02890-a 20v present but no ppbus
the ppbus is 12.4v for a split second then it drops to 5v and continues to drop dramatically down to 1.7v. the amp meter stays at 20v 0.000a
"smbus_batt_scl/sda is .222v"
Is that voltage reading (power applied to board), or diode mode reading (no power)?
BTW, do not write end "V" after diode mode readings...
If PPBUS_AON is not maintained, you can't measure any other voltage on the board.
Remove F5200/1 and check if C5250 voltage is stable.
Looks like you have problems with a secondary power supply.
Start checking all of them in diode mode and voltage pulse on outputs.
