820-02899 - 5V / 0.020A
I never understood why people like to check that coil.
Any fault history available?
Is the machine recognized into DFU?
"I never understood why people like to check that coil." because lot of times you say test big coils
No history available. Dead directly
This machine not recognized in DFU mode
"because lot of times you say test big coils"
I never mention charger coil on my list, for this kind of back-boost converter!
Check U8100 and U7700 LDOs.
I recently had a MacBook Pro do the same thing, and it was the USB-C Controller. For your model, I believe it is the CD3217B12 IC. There should be two, and both should be replaced if that is the issue. I would check around there.
