820-2330 PP5V_S3 missing
ajdoc
Tested with genuine 85W charger.
Cant find any liquid on board but trackpad is damaged by liquid which is powered by PP5V_S3_TPAD and I think thats why 5V rail is missing.
Got light on charger and was checking list of power rails and PP5V_S3 is missing.
There is no short to ground when there is no power on the board, but when charger is connected got short to ground on PP5V_S3.
Don?t know much about 5V / 3.3V Power Supply but thats what I got.
U7201/16 @12.62V
U7201/3 @2.001V
L7260 @3.33V on both sides
L7220 @0.0V on both sides
Q7210/3 @3.40V
Q7210/5 @0.0V
PM_SLP_S4_L @0.0V
Thanks in advance
JohnB8812
Are you shorting the power pads to try and turn it on? If so, what is your resistance to ground on PP3v42_G3H?
"when charger is connected got short to ground on PP5V_S3"
You are not the first, but I recommend you STOP to check continuity on a powered board!!!
Trigger SMC_ONOFF_L signal and see if PM_SLP_S4_L pulses at least.
Did you try to start in SMC bypass mode?
ajdoc
JohnB8812
When shorting power pads nothing happen.
Resistance to ground on PP3v42_G3H is 3.030 kOhm
"You are not the first, but I recommend you STOP to check continuity on a powered board!!!"
Thanks, will not doing that anymore :)
"Trigger SMC_ONOFF_L signal and see if PM_SLP_S4_L pulses at least."
No pulse.
SMC bypass - still dead
"Resistance to ground on PP3v42_G3H is 3.030 kOhm"
Too low, MCP is dead almost sure.
You must get more than 30K there...
