820-2523 right fan high (0 RPM)
BCN_Techs
Got this board. No water damage.
Right fan is always high. When start it has some delay and after 2-3 seconds start run very high.
Already changed U5570 and Q5501. Same result.
Run AHT and it it gives me 3 errors:
Fan-Right side (test1) Qiuck motor test-> Error - MOtor is spinning slower than should
Same with test 2 fo right side fan
And
CPU Front Side Bus (1,05V) current (test) -> Sensor is reading above the high limit. +
Check traces and components around U5440.
Also check continuity to R7660.
Post SMC_CPU_FSB_ISENSE level.
BCN_Techs
Near u5440 all is ok.
R7660 you mean continuity on same resistor? If so there is continuity there is 1.05V on both sides.
SMC_CPU_FSB_ISENSE 3.3V
BCN_Techs
R5495 4.5 Kohms
U5440:
1 - 0,8V
2 - 1.5V
3 - 1.5V
5 6 - 1.05
7 - 0.6V
8 - 3.3V
Must change U5440 ? I see that entering voltage is ok but outgoing is low, right? Must be about 1.05 on Pin 1 and 7
BCN_Techs
ALl measerment were done when board was on.
If board is off:
1- 6 are 0V
7 - 1..05V
8- 0.5V
There is continuity from U5440 Pin 7 to R5495 and R5495 is 4.5 Kohms
Who cares about off state, if is an S0 voltage?
R5495 MUST have the same voltage on both pins.
You may need to change SMC...
BCN_Techs
Just reflow SMC and now it is working. but anyway R5495 has 0.5V on pin 1 and 3V on pin 2 but fan not running high speed like before.
