820-2530 no PM_SLP_S3_L
XooP
Got one more of these old 820-2530 boards. I have all main power rails and I have PM_SLP_S4_L. When pressing power I only get 0,78V on PM_SLP_S3_L should be 3.3 I think.
There is no short to ground and all the enable resistors and capacitors on this line is fine.
Is this bad SMC?
XooP
Both sides the same 0.106, which is what I get everywhere i measure PM_SLP_S3_L when i press the power button. It raised from 0 to 0.1V when button is pressed. One more thing i wrote the wrong value i the first post it should be 0.078-0.1V.
XooP
Shouldn't matter if the charger can handle more than 60W. If I was using a 45W charger, then it could be an issue.
No! 15" board will NOT power on from anything else than an 85W charger!
I have no more ideas about this one really, any history on this board, water?
XooP
You know this is a 13 inch board? And yes it was as originally water damaged
