820-2530 No Power No S3
Bouba148
No History
Doesn't Power ON No Green Light ( Very dim)
PPBUS_G3H: 12.58V
PP3V42_G3H: 3.418V
ADAPTER_SENSE_R: 16.44V
Replaced the magsafe connector board:
Green Light OK
ADAPTER_SENSE_R: 3.398V
Then no S5 State
PP3V3_S5: 0482V if L7220 removed then 0V on Pin 1
3V3S5_ENTRIP: 0V
SMC_PM_G2_EN: 3.396V
Replaced U7200:
PP3V3_S5: 3.317V
PP1V1R1V05_S5: 1.059V
Then No S3 State
When shorting the power pads PM_SLP_S4_L is pulsing
At MCP79 (U1400):
SMC_ADAPTER_EN: 3.401V
PM_BATLOW_L: 3.313V pulsing to 0V when shorting the power pads
PM_PWRBTN_L: 3.417V pulsing to 0V when shorting the power pads
RTC_RST_L : 3.403V solid even if shorting the power pads
MCP_PS_PWRGD : 0V and slightly pulsing when shorting the power pads
32kHz is OK
Mesured the resistance to gnd of PP5V_S3, and I have around 20 Ohms and in diode mode it's 0.021V which is too low and means that I have a "short" to gnd on that rail.
Removed L7620 and the short is on the pin 1 side the same for R7267 not on the U7200 that I've already replaced before....
Lifted C7290, C7291,C7293 and C4801 still have the short.....
After a deep inspection of the board I've noticed that C6603 was fried and removed it: still the same.
So I also removed all the audio amps and their capacitors: U6610,U6620,U6630, C6601 and C6605 and the short is still present......it could be anywhere on the PP5V_S3 rail.......but now the resitance to Gnd is 26 Ohms....
Bouba148
I will check all the associate rails to PP5V_S3_REG:
=PP5V_S3_P5VS0FET
=PP5V_S3_ODD
=PP5V_S3_AUDIO_AMP
=PP5V_S3_AUDIO
=PP5V_S3_1V5S30V75S0
=PP5V_S3_TPAD
=PP5V_S3_WLAN
=PP5V_S3_VTTCLAMP
=PP5V_S3_MCPDDRFET
=PP5V_S3_SYSLED
=PP5V_S3_IR
=PP5V_S3_BTCAMERA
=PP5V_S3_EXTUSB
As it's a long job and this board is not urgent I'll do few of them time to time
Check first resistance to ground on 3V42 power rail in ohm scale; you should get more than 30K.
Lower value points to bad MCP...
Bouba148
Resistance to GND for PP3V42 is 2.5KOhms
And here my mesurement regarding "short" on PP5V_S3.......but if the MCP is bad It doesn't worth to continu removing the ones I haven't done so far.....
Removed components:
For PP5V_S3_P5VS0FET: Q7940
For PP5V_S3_ODD: Q4590
For PP5V_S3_AUDIO_AMP: U6610, U6620, U6630, C6601, C6603, C6605
For PP5V_S3_AUDIO: U 6200, U6500, C6213
For PP5V_S3_1V5S30V75S0 : R7307 and C7302
For PP5V_S3_WLAN: Q3450
For PP5V_S3_TPAD: R5873 ( short stay on pin 1) , C5800, R5805 ( short stay on pin 2)
For PP5V_S3_SYSLED: R5030 short stay on pin 1
For PP5V_S3_MCPDDRFET only checked Pin 2 of R7901 and R7903 for short: None
For PP5V_S3_VTTCLAMP only checked fort short on Pin 2 of R7976: None
For PP5V_S3_BTCAMERA: Removed L3405 looking for short on the Camera connector: None
For PP5V_S3_IR: R4532 short stays on Pin 2
For PP5V_S3_EXTUSB: U4690 and C4691
Next Time I Will still have to remove U6201, U6700 for PP5V_S3_AUDIO
and U4800 C4801 for PP5V_S3_IR
Please confirm regarding bad MCP......
