Hello,
working on this 17" 820-2610 came to me not starting with C7771 issue (.3V). I replaced C7771, but still the same. I also replaced U7750, but still .3V. Does that point to the MCP itself, or is there anything else that could cause this and that I am missing here?
I used only my Iron for that. U7750 I replaced with hot air, but I removed the heat sink from the board and shielded the surrounding area before. Also pointed hot air towards the edge of the board...
I checked everything around U7750 before I decided to replace it. Everything seems fine as far as I can tell. So I thought it just could be the chip and replaced it.
I measured the same voltage with no cap installed at all. I don't have the same board to compare to. My reading is 0.251V to GND on C7771. Maybe somebody has a value/experience to compare it to?
Datasheet says enable (Pin4) should be >2V. R7801 is fine (5K1). I get 3,38V at R7801 Pin 2 and 1,5 at Pin 1. Is that normal? I removed C7801 for testing but same thing. Other signals (Pin2, 12, Output, Feedback, etc.) could be messed up if the enable is missing or not high enough I think.
Sorry, I mixed that up with 820-2850. I mean MCP as it receives the voltage from U7750 and I don't have a reference to my measured resistance on that line. So MCP could pull that voltage down, maybe? I'd try lifting L7770 and see if U7750 can produce its voltage then?
I don’t have the scematic in front of my eyes right now. Without the coil I thought the voltage would be not as steady as with a coil in place. But I would suspect it being higher than a steady .3V. If the multimeter would not be capable of measuring this I would have used my CRT. My plan was to lift the one pin off the coil and put it at an angle (on the MCP side) so that I can measure the voltage from U7750 after the coil with no load attached to it that could pull it down. I will check C7770 tomorrow and report back. As I don’t have the schematic with me right now I can’t tell for sure but I probably did already check and maybe replace it. Before opening the threat I looked at pretty much every component and voltage in that circuit…
Sorry. I had no schematic on hand and wrote that post from my phone in a hurry. You are totally right. There are important signals after the coil that U7750 needs, like FB, so it can't work the way I suggested. I thought from my memory of the schematic that lifting L7770 would be equal to removing F7040 on PPBUS_G3H... My bad. I'll look at the schematic first next time.
To answer your question: I replaced C7770 and still only 0.32V at C7771.
