pin 25 on U7600 present (2.8v)
CPU_VTTSENSE_N is 0.8ohm to ground. Diode mode is 0.
CPU_VTTSENSE_P is 12.8ohm is ground. Diode mode is 10.
Is this not normal?
I decided to change the SMC, which seems to fix the intermittent PPCPUVTT_S0. It is now always 1.05v. Does SMC has anything to do with PPCPUVTT_S0?
Fan will startup slowly turn high, then low and then stay at high.
But now, I found out PLT_RESET_L is 0v. Diode mode 317.
Is this not normal?
