Jimmy Spangle
Ok guys. My first problem to post and I hope you will be able to help with this.
This is a 2010 Macbook Pro 17" that I purchased from a someone this week. Sold as 'not charging, tried 2 different chargers' and I took the chance on the basis they probably did not know you had to use an 85w magsafe. Anyway, got it, plugged in and green light straight away which is always nice. Battery is no good, so cannot tell about charging as such yet. Have checked both current sensing circuits for DC in and battery, both check out fine.
On removing rear cover I immediately honed in on two red flags. One, the fans were spotless. Two, flux around U7201. Someone has been telling uncle Jimmy porkies!!!!! Clean fans usually means someon has been in and doing something, albeit just cleaning someone has been in here first which I hate.
So, to the problem so far. Have ppbus_G3H at 8.4v. Have pp3v42 obviously and needless to say DC in etc. PP5v_S5 at C75205 was coming up at 0.7v.
Straight to that U7201 for a closer look and although it seems to be the original (no tweeer marks) and seemed to soldered well, replaced it as a matter of course. Whilst it was removed I measured pin 1 of R7901 for EN signal and got a nice steady 3.3v as hoped. On fitting U7201 that dropped to 2.4v. Replaced U7201 again just to be sure chip wasn't bad and got exact same result.
Pin 1 of C7205 is showing 0.772v with both the new chips.
A little bit baffled by this one. Racking my brains so ANY pointers will be gratefully received.
Thanks
Jimmy
Thanks
Jimmy
