820-2850 Restart when shutdown in OSX
Don Anton
This is a clean board. No liquid damaged. It can turn off by pressing power button. How ever when it shutsdown from osx restarts.
SMC_ONOFF_L is 3.3and when shutdown goes to 0v and back 3.3 as usual.
Any idea?
Did you try PRAM reset?
Also try known good USB OSX, disocnnecting internal HDD/SSD.
Don't forget to test without battery too.
Don Anton
I notice one thing to shutdown from the power button need to hold for 5 second to turn off. if i press the power button for 2,3 seconds it restarts.
Don Anton
Also tried with different macbook, and L?B out of the body connecting external monitor usb mouse and usb osx. still same
Don Anton
HI Info, This is SOLVED. I noticeed PCIE_WAKE_L was going down to 1.9v after couple of seconds. check resisters all good. Replaced U3900 SOLVED. Thank you very mcuh for your help. See you until nest time I trouble you.:D
