820-2850 Screen Whites Out Wheel Spins Desktop Shows But Mouse And Keyboard Freezes
supamodz
Hi guys im Working on a 820-2850 Core I5 Unit, which was repaired by l2 computer. Now its in my hands trying to figure out what is causing the mouse and keyboard to freeze. It turns on fine but the screen will go white for 5 seconds then wheel spins, after that the desktop shows but mouse and keyboard stops working. My customer replaced the hard drive and same problem, i ran asd on efi and test passed any ideas on what could cause this.
I have no idea what they fucked up. I doubt this will be worth the headache.
Is the machine locking up or is just the USB that stops working? Play a video and see if it keeps going once USB stops.
complete lock up mouse is frozen keyboard does not type and usb ports are dead but boots up to the desktop fine
You did not answer my question. All things you mentioned are USB devices, so I don't know if it is just USB that stops or the whole system.
l2 are you kidding me, GPU reflowed 20x over without even removing the edge bonding. this is junk!!
let me explain again, the system turns on boots up to the desktop but after it loads the mouse pointer is stuck and does not move keyboard does not type trackpad does not function and if i plug in a usb thumb drive it does nothing it should light up.
are you serious how the fuck do they reflow without removing the boding i suspect they fucked with the gpu. ill try replacing those chips i mentioned cost me 40 bucks for 2 donor boards if it does not work i will trash.
Did you run ASD EFI? Is the mouse working in EFI mode?Is it getting stucked like in OSX?
Did you run ASD OS? Do you have the same problem like in OS X
Did you try replacing ram modules?Did you try with another HDD or SDD? When you get wheel spinning could be because of ram or hdd most of the times.
Do you get any light from an external mouse when you plug in into the usb ports? Which ones are working?Which ones are not?
