820 2879 b green light no fan spin
Modder1
Got myself a water damaged 820 2879
green light and no fan spin.
ppbus_g3h =12.59
pp3v42=present
pin 14 u7000 3.24 smc_bc_acok
3.34v pp3v3_s5
not sure if any of those measurements help.
kind regards
That's probably a bad MCP89. You can buy a replacement but half of them will be worse than the one that you have.
if shorting power pads = pin 5 of J5713 to GND then the fan spins for a short time. I am not holding wire for more than a few seconds.
Holding it for longer seems to kick the fan into high. I also do not have the board in the body at this time. I am unsure if this makes any difference.
out of body is no problem,
hook up the speakers, the plugin charger, then short pins 5 see if you hear a chime. or if you hook up a mouse if the light turns on on the mouse
See if you hear a chime is for the deaf people sorry for that, listen if you hear a chime.. gosh i am a dick
