820-2879 - no backlight after i restart the computer.
Alan.L
board was liquid damaged. L9008 was burnt, R9731's pin1 was burnt too, few led returns resistors.
after repeal and replace, the backlight has come back on with image. but every time i restart the computer, the backlight goes out.
D9701 pin 1 has 12.46v , pin 2 has 27.54v when backlight is working.
D9701 pin 1 has 12.52v , pin 2 has 12.5v when backlight stop working.
PRAM reset. same problem.
ive replaced led driver twice. i also replaced, lvds connector even tho is good.
i've tried few lcd panels and new cable already.
bad boost circuit?
Sync problem?
bad smc or mcp?
reflash the bios didn't solve the problem
if i wake from sleep, the backlight will turn back on.
Alan.L
SMC_LID
3.395v with backlight
3.395v without backlight
BKL_EN
3.105v with backlight
3.110v without backlight
BKL_PWM
2.952v with backlight
2.935v without backlight
Alan.L
i need to change R0910? im pretty sure i've changed this. ok i'll change it.
could be the L9701 coil has gone bad?
reason because i just fixed a macbook air 11" 2011. with no liquid corrosion on the lcd area. it had a similar symptom where sometime backlight doesn't work.
the measurement on the coil sometime isnt correct and sometime correct. so i changed this coil then backlight now always work,
I really have no other solution then to just replace all parts in the BKL circuit. Checking traces too while you have resistors/caps off the board.
Alan.L
duke, do you think it has SMC issue. when i have backlight then i press restart then i quickly put a magnet over the sleep sensor, it rebooted and backlight appear
As long as enable and pwm are present there should be backlight. So i suspect something in the backlight circuit
Alan.L
i'll already checked every resistors and traces and even replaced some components that looked good. i dont have smc for this board. i give up and move on to something else.
