820-2879 turning on, green light, no orange not charging.
BCN_Techs
Sorry, i mean U7000 not U7200. It was liquid damage that area.
R7051/52 are ok with continuity, R7050 too.
JohnB8812
So your problem is pins 17/18 is it 2.9 ohms or millions still? If all check good, then your problem is the ISL it seems.
JohnB8812
So one of the few has to be true above there is no way all the resistors are ok and the traces. That's literally not possible unless you're measuring the wrong spot.
BCN_Techs
Something strange is happening. PPDCIN_G3H_INRUSH is going up to 36 V when magsafe is connected and i connect the battery without booting logic board. :S Q7080 recieves 20V and gies 36V. IS that the problem?
Did you try other multimeter?
Why you do NOT do what we ask to do???
Solve R7051/52 issue!!!
If resistors are OK, then rebuild corroded traces...
BCN_Techs
Solved. Changins ISL. Seems it was burning every time i put new one while there was damaged trace. Thank you very much:)
