820-2914-B, turn on but stuck on 44% battery
Does it charge until 44% and then stuck?
Magsafe light must be orange to charge battery.
If you don't get green at least, never will charge.
Any history available?
Post exact PPBUS_G3H voltage without battery connected; also with charger + battery.
Need U6900/01 voltages too.
Check continuity from U6900 to central pin of Magsafe connector in DCIN board.
Did you try known good DCIN board?
yobad
no it not charge at all
PPBUS_G3H 12.5V with and without battery (why to test with and without battery )
U6900/01 3.3v
SMC_BC_ACOK 2.5 to 2.9v
yes I already tried a new DCIN
no history
yobad
U6900/
05 2.9V
04 2.9V
01 3.5V
SCL/SDA 0.503 dido mode
but I don't have a green light on MagSafe even without battery
yobad
GPU was replaced in China
suddenly it worked, but stopped after I replaced DCIN again it worked for a while it stopped again.
I just reballed SMC same ...
i dont have SMC now but i will order one
"it stopped again"
Still no light on magsafe?
If board reacts after applying heat, could also be PCH problem.
Resolder ISL6259 too.
