I am struggling to get the correct ASD OS, some more comments:
1. When entering boot menu, the image on the screen distorted once and the computer restarted (just like when I entered the password to enter the user). Could this change the assumption of the faulty IGPU?
2. I got the ASD OS 3S148, but its been loading for 20 minutes and nothing happen (apple logo with loading circle).
This is the a MacBook Pro (15-inch, Late 2011) built in the second half of 2011 with 2915 board. Is that the correct ASD?
3. I am seriosly considering replacing the CPU on this, good possibily of the being the a CPU issue?
CPU working frequency is adjusted, depending if battery is present, or not.
The battery can supply peak current, if the power from charger is not sufficient; when CPU enters turbo boost mode, for example.
