820-2915-B turn on, no video
HOSOI
Hello, this MP turns on, charge, have green and orange light at MagSafe, but there is no video and no chime either, there is no sign of water or burned parts, flashed the spi just in case and nothing, removed the ram and no beep, connected external monitor and nothing. any clue where to start?
BR
HOSOI
PLT_RESET_L __3.34
PP5V_S5__5
PP5V_S3__5
PP5V_S0__5
PP3V3_S4__3.34
PP3V3_SUS__3.34
PP3V3_S5__3.34
PP3V3_S3___3.34
PP3V3_S0__1.34
PP1V8_S0__1.77
PPVCORE_S0_CPU__1.14
PP3V3_S0GPU___3.34
PPVCORE_GPU___1.11
When board boots, VCORE must drop to 0.75V aprox.
Try one known good DDR module, one slot at a time.
I'm not sure if works with PC3-8500; try 10600, or 12800, just in case.
HOSOI
VCORE drops to 0.75 without the battery connected and just the display and ram on it, but with the battery connected, the display, and ram it drops to 1.06. is that normal?
Let the battery out for the moment.
VCORE drop looks like board boots.
You may have GPU issue.
Should be good to disable GPU in BIOS, just for test.
HOSOI
nothing happened sr. Everything still the same. no video at all, I confirmed that there is mouse activity, noticed that the DVD ROM is not powering on, before flashing it was. I also tried an external monitor just in case. I'm curious about something, why there is no beep when there is no RAM? as I know it should, please correct me if I'm wrong. thanks.
If board can't boot, no RAM error posibble.
BTW, modded BIOS disable external video.
Did you remove mentioned resistor, before applying power?
HOSOI
of course, I lifted one side of each resistor.
in this case what next? flash the original bios back?
HOSOI
yes, VCORE drops to 0.76, and there is USB activity I connected a USB ethernet adapter and I have link on the adapter and the switch as well, but like I said is weird cuz if I remove the ram I dont get the beep for no ram on it and I also have usb activity without ram. I did smc bypass and the fan spins faster. what else should I do or test?
Impossible to have REAL USB activity without RAM.
Without RAM, VCORE should stay higher.
Use macOS USB pendrive with Link LED; if flasshes there is USB activity.
HOSOI
with the USB pen drive there is no activity, and yes without ram VCORE stays high, so what next then.
