820-2915 No chime no video
Ryanlen2
I have this 820-2915 that powers on but I don't get chime, video or light on USB mouse. No liquid on the board.
CPU Vcore - .738V
GPU Vcore - .903V
Tried another BIOS for testing with no success.
Any thoughts?
Thanks, have a good one.
aurel476
if you plug external hard drive with os x installed have you led activty bliking ?,
if not heat gpu 120°C and try
Does CPU VCORE start with 1.1V and drops to 0.75V after few seconds?
Usually means board is working...
So board works, has even USB activity.
PRAM reset should work then.
Post some voltages from LCD connector.
Ryanlen2
USB activity on the external USB SATA adapter but not on the mouse. I double checked the mouse to be sure it was fine. Weird...
PRAM has not been working. I will try again and post SW_LCD voltages.
Thanks again!
