820-2915 No image / no backlight
grmacs
I've already spent too much time on this and guessing it isn't worth anymore, but this had no image or backlight when I got it. I tried real mac mods bypass and nothing. Also tried to flash gmux to bypass and that failed over and over. I've done both of these on multiple machines successfully. Lastly I jumper wired the bypass but still no image or backlight so I'm guessing theres an issue with the integrated GPU? or traces? No signs of any other issues when inspecting the board. Thinking i should get a backlight with the jumpers regardless of image but... maybe not.
SMC LId is +3V. Other things that might prevent image?
grmacs
Yes sorry meant to mention that I get post, chime & data activity. Also LVDS connector and cable looks perfect, (i tested with another LCD just in case with no change) components directly opposite LVDS on board for LVDS data look good.
Image should appear before backlight.
Is the only way to prevent artefacts and unstable video.
No real reason to search for backlight, if no image present.
After all the changes you did on the board, I'm not sure if can still be recovered.
Why did you try hardware mod, if you have GMUX flasher???
If you didn't get external video, there was GPU problem.
External monitor is always driven by GPU...
