820-2915 no pp3v3_sus
farfan14
hello. i have 820-2915 board. it doesn't have any visual damage. it doesn't have pp3v3_sus.PM_SLP_SUS_L present. please advice me from where should i start? in SMC_BYPASS mode it's started and presents PP3V3_SUS 3.3V!
PM_SLP_SUS_L 3.3V
PP3V3_SUS - 0V no short to ground
P3V3SUS_EN_L 3.3V
PPBUS_G3H is 12.58v with/without battery on 85w charger
PM_BATLOW_L and SMC_BATLOW_L with and without battery have 0v
PP3V3_S5 -- 3.3V
"in SMC_BYPASS mode it's started and presents PP3V3_SUS 3.3V"
Does it boot then, or just stays on without any activity?
Check AVREF_SMC voltage.
farfan14
yes its booted in smc bypass mode there is chime, apple logo, loading bar about 60% and than restart and same ....
AVREF_SMC have 3.3v
farfan14
during this state SMC_PBUS_VSENSE must be or not ? there is 0v
SMC_DCIN_VSENSE have 2.7v
SMC_CPU_VSENSE 0v
SMC_GFX_VSENSE 0v
SMC_GPU_ISENSE 0v
SMC_GPU_VSENSE 0v
SMC_CPUVCCIO_ISENSE 0v
SMC_SA_ISENSE 0v
SMC_P1V5S3_ISENSE 0v
SMC_CPU_HI_ISENSE 0.6v
SMC_GPU_HI_ISENSE 0.68v
SMC_OTHER_HI_ISENSE 0.68v
SMC_BMON_ISENSE 0.05v
SMC_DCIN_ISENSE 0.2v
SMC_CPU_ISENSE 0v
SMC_GFX_ISENSE 0v
p.s during this testing i suddenly saw that green light wasn't on the charger. i checked ppbus_g3h and is only 0.9-1v. tried detach and plug several times and nothing changed. still 1v. during this 2 days it happenes first time. but now still 1v
update: after several detach and plug now back to 12.58v
Are you using 85W original Magsafe 1 charger?
Board still doesn't start with both charger and battery connected?
What said the client about how problem appeared?
farfan14
i don't have another 85w original magsafe 1 charger. is there any method to check possibility of charger problem? can i test by multimeter on the motherboard if charger is not enough for anything ?
