820-2915 not charging
only greenlight PPBUS_G3H 12.25v using 85w fake charger.
j6950 scl/sda 3.4v
u7000 pin 17-18 3.5ohms 27-28 21.1ohms
1. 0v
2. 16.2v
3. 3.9v
9. 0v
12. 3.4v
13. 3.4v
14. 3.3v
15. 0v
17. 12.25v
19. 5v
20. 5v
25. 16.5v
27. 16.1v
previously replaced q7035 cause chrg_phase is shorted also replaced u7100
Post voltage and diode mode for SCL/SDA lines of battery bus.
Check w/ and w/o BIL connected (J6955).
If no good, remove D6950 and test again.
SCL 0.521ohms 3.4v stable
SDA 0.502ohms 0v-3.4v looping with/without D6950
w/ and w/o BIL nothing changes
You should get less than 1% difference between both lines; in diode mode.
Remove C6952/53 and test again.
If still the same, change U7000.
SMC is the last option.
BTW, battery should be removed...
