820 2915 what do you think ?
Possible, but you would need to run at least 6 wires around the MUX to bypass all the LVDS channels. Also EDID data lines are MUXED and the backlight control in done by the MUX. I'm not going to waste time to see if this will work or not.
The real solution would be a BIOS/SMC mod as that is where everything is controlled on a hardware level.
Look at diagram and see where LVDS comes from the PCH and should go to the LCD. But no need to solder them as the first thing you should get to work is EDID and backlight. Look how EDID is MUXed, I already tried to tie it so that on boot EDID went to the PCH but there was no backlight. The default of booting on GPU needs to be changed and the only way to do that is a hack that does not work after a PRAM reset.
smiba
The obvious details like serial number on the board and on the machine eventually booting match so I'm honestly thinking they may have succeeded.
Its more then the two wires in your post though, you see the video is cut and they suddenly have a bunch of wires running around the MUX as well. Who knows what else they've changed what we can't see.
I don't believe the device will work 100% with just a few wires though (for example I don't think connecting a monitor will work anymore), as the programming of the SMC and/or BIOS still assumes its running with a dGPU in mind. But I never looked into it so who knows.
You should run 8 pairs for LVDS A and B channel, data and clock (16 wires).
Two more wires for EDID (LVDS_DDC lines), bypassing any issue with U9270 (if required).
I personally forced PEX_CLKREQ_L to 0V, didn't help (R8795 removed).
I also forced GPU_RESET_R_L to 0V (R8000 removed), didn't help.
I moved R9645 to R9646 (changing GMUX_CFG0), no way...
I didn't see any way to force down PEG_CLKREQ_L without damaging board, or removing GMUX.
Remove GMUX is not an option, as it controls backlight based on LPC signals from SMC...
So needs to run at least 18 wires and maybe still needs to change some rsistors position.
I will probably try it one day, not so soon...
As Duke said, modded BIOS/SMC should do the trick, but who can mod it?
