820-2936-B No backlight
Triple6r
Hi guys iam new here . In the past i fixt a lot of old mackbook airs 2008-2009 made a money with it. After a few airs that i cannot fix i look closer and start learning and watching day in day out louis his youtube channel.i bought a macbook pro with no backlight to start learning
i start looking at the schematics for this model 820-2936
i got 12,6 dc on F9700 it was the first thing a put my fluke on
i got nothing on c9796 olso
can you guys tell me what to look for
it has no waterdamage
greetings triple6r
12V on F9700 is not enough info. You should measure if 12V is on both sides to make sure it is not blown.
Is there an image on the LCD? Was this liquid?
So the fuse is blown. This happend because of a short on the backlight output. Measure resistance to GND on C9796.
ALB-Repairs
someone probably blew the fuse, carefully insepct the screen cable and connector, if nothing seems wrong replace f97000 and see what happens
Triple6r
Hm i have put other screen on it and same problem and i put a light on de back of the screen and go to webcam and that olso not working?
Triple6r
I did replace it it got backlight now but nou only got white screen it start up it chaims i here donggg ?? Did i hit something with replacing the fuse
Hold down the ALT key while turning it on. Disconnect any HDD. Do you get a boot menu? If not what is the voltage on C9015?
So no power to the LCD. I bet L9004 is fried. Check for a short on C9015 first before replacing it of course. LCD plugged in!
Triple6r
I see that i got a strange looking L9004 ? Can that be the problem but how can that be before i got image no backlight now i got backlight no image
0.9m as in milli or Mega? If low then unplug LCD and see if short is gone. Inspect cable/connector for damage.
ALB-Repairs
sounds like you are measuring to GND and not measuring across the suspect component.
Measure across pin 1 and 2 of the component
Triple6r
I got when i measure across pin 1 and 2 with lcd cable 4.216 k ohms (c9015)
and with no lcd cable plugd 204.4 k ohms
