820-2936 gray screen
Kyle93
Have a 820-2936 that had water damage in lcd area. Replaced everything affected and now screens turns on but is gray. This is a test lcd so I know that is not the issue.
What to check first?
You still have liquid affected components, or traces.
Did you change LCD connector?
Check all data lines in diode mode to ground and voltage; compare with similar working board.
Be sure L9080 is OK.
