820-2936 green light OK, PPBUS _G3H 3.46V
Rozakis
Hello guys,
someone tried to change the battery on a 820-2936 MacBook with a fake one and now it does not start. I get a green light in the charger but PPBUS_G3H is 3.46V.
On ILS chip U7000 I measure resistance 17/18 3.2Ohm and 27/28 is 20.4Ohm.
What do I measure first?
First, diode mode to ground at L7030.
Next some voltages for U7000; pins 1, 2, 3, 9, 12, 13, 15, 19, 20.
Try to start in SMC bypass mode.
Do not connect battery again, untill get the board working on charger only...
Rozakis
So, Diode mode to ground at L7030 is 0.442V
U7000 pins measures:
pin 1 0.003V
pin 2 16.34V
pin 3 3.93V
pin 9 0.028V
pin 12 3.469V
pin 13 3.437V
Pin 15 0.047V
Pin 19 5.03V
Pin 20 5.03V
How do I start in SMC bypass mode?
Check again, you have too big difference; should be less than 1%.
If still bad, remove D6950 and check again.
Also disconnect BIL connector.
Next step, if needed, remove ISL6259.
If still difference, SMC is the last option...
