820-2936a missing pp5v_s3
If no voltage, post resistance to ground (diode mode).
Must find why no voltages there.
Also post voltage and resistance for EN0.
"l7260 0.036"
That's no good.
Remove power and wait 20s before measure diode mode on board...
Measure both directions, red and black at ground.
0.007 in diode mode is aprox 10-15 ohms in 200ohm scale.
Something is strange with your measures...
Put red probe on ground and touch the coil with black probe; note the value.
Invert the probes and note the other (reverse) value.
So both lines shorted to ground practicaly...
How do you explain these values then?
"L7220 0.125
l7260 0.036"
If I'm not sure about your values, my replies will not help you.
Kyle93
at this point i believe there is a short inside the board. When injecting 5 volts in the line u7200 gets boiling hot but parts of the board get hot that have no components on them. Removed all capacitors on the line and still have a short
Kyle93
worked on this board more and removed the short which was u4800 but now all of my voltages are off ppbus on f7040 is only 1.1V. What can cause this? What to check now?
Kyle93
c7334 near u7200 is also very warm to the touch. not sure if this means a short inside the board since this is no stuff
Kyle93
there was correct voltage on c7040 after f7040 was removed
q7260 and q7220 do not have shorts.
vreg3 0.113 v vreg 5 0.083v vref 0.113V
cant be the chip itself. already replaced it with new
Kyle93
dummy me soldered q7260 backwards. I replaced it again, soldered it in right position and now I have new voltages and nothing is getting hot. PPBUS_G3H back to 12.60V
pp5v_s3 0.602V
PP5V_S5 0.482V
what to check next?
Kyle93
should u7200 be replaced again now since it was burning hot so many times while trying to find the short?
pin 16 12.60V
pin 17 0.489V
VREG 3 0.601V
VREG 5 0.489V
