820-3115 alain, weird issue, no power on with charger but will run off charger
peterfixit
water damage?, coke spill in november
green light, fan spin, no chime with charger plugged in,
no charger, running off battery, boot with folder icon
plug in charger, disconnect battery, folder icon remains
after running for 5 mins weird smell
no apparant corrosion
scratching my head, checked one wire, seems ok checked d6990 and u6990, seems ok
peterfixit
I only have 80w chargers in my office
something strange,without the battery plugged in the voltage out of the battery connector is 3v something,
when the battery is plugged in it starts charging 11.5v going up past 12.06
orange light is on
peterfixit
geniune charger, again, I only have genuine chargers
ok starting with the battery plugged in first and then plugging in the charger to turn it on
ppbus_g3h 12.03v ppbat 12.06 orrange light
unplug charger
ppbus 10.97v ppbat 10.95v
plug back in charger, unplug battery
ppbus 0.227 ppbat 12.61
Im trying to give you as much info as I can because I have to wait 24 hours to get a message back, I will measure what you want measured
Lets get some new measurements now.
Voltage on PPBUS without battery connected?
ADAPTER_EN present?
Do you get an orange light when battery connected?
peterfixit
ive reflowed the smc and now i get a fan spin, no chime, no green light, turns off using power button, wont turn on using power button, only cable in, i thought this was one of the models that didnt turn on then the charger was plugged in, turns off after like 30 seconds of being plugged in
