820-3115-b board dont boot white led
turbo
820-3115-b board, had slight water damage, all cleaned good now , now its turns on ...does not boot, white led keep on ,
cpu vcore good,
any idea , where to look
pls chk picture
Alan.L
remove the BIL to see if still turns on. any image on screen, shine light to screen?
also SMC_LID value?
No drop at VCORE, board is not functional; no need to check USB mouse.
Check around SPI chip, for corroded resistors, traces.
Don't forget R7403...
turbo
usb mouse=no light ,
cpu vcore 1.12v,
aux cpu vcore....=0......
both ton register good, R7403 etc
SMMRepair
Just for testing, swap the BIOS/SPI ROM chip from another 3115 onto this board. If it chimes, you have either bad BIOS or dead/faulty chip.
If you DO get a chime/boot, then load up a new BIOS with the original/correct serial number, MLB and a clean ME region. PRAM on 1st start.
If you DON'T get a chime/boot, then you can eliminate BIOS/SPI ROM chip as the cause, and replace the original chip back on the board.
ALB-Repairs
Try ram slots one by one, Reseat Ram.ect
You have high v-core. It can be:
Ram not so good
SPI ROM
And often can be caused by a bad SMC.
turbo
did that , no boot/chime
turbo
No Title
here im posting some original water damage pic . b4 cleaning ....... pls chk the pic and let , know, i took out and thunderbolt chip and those is, those are good, also i put it back,
fan spinning high speed no, boot... which region i should chk first...spi chnged still the same, ......
cpu vcore good, 1.12v....
aux vcore 0v
