820-3115-B board only works on SMC bypass mode
regular mode, plugged inSMC bypass mode
CPU_ISENSE0v0v
DCIN_ISENSE0.04v0.04v
HDD_ISENSE0v0.01v
BMON_ISENSE0v0v
CPU_HI_ISENSE0.07v0.01v
OTHER_HI_ISENSE0.08v0.02v
MEM_ISENSE0v0v
CPUVCCIO_ISENSE0v0v
AXG_ISENSE0v0v
CPU_VSENSE0v0v
DCIN_VSENSE0v2.08v
PBUS_VSENSE0v1.4v
AXG_VSENSE0v0v
I could compare these to working board if you want but they seem to be mostly 0v or near it except for the two that work in SMC bypass mode.
Why would you want to check them in normal mode, if board stays off???
Compare the readings in SMC bypass with any other board which turns on.
regular mode, plugged inSMC bypass modeWorking Board
CPU_ISENSE0v0v0.10v
DCIN_ISENSE0.04v0.04v0.33v
HDD_ISENSE0v0.01v0v
BMON_ISENSE0v0v0.06v
CPU_HI_ISENSE0.07v0.01v0.12v
OTHER_HI_ISENSE0.08v0.02v0.09v
MEM_ISENSE0v0v2.64v
CPUVCCIO_ISENSE0v0v0v
AXG_ISENSE0v0v0v
CPU_VSENSE0v0v1.11v
DCIN_VSENSE0v2.08v2.72v
PBUS_VSENSE0v1.4v2.09v
AXG_VSENSE0v0v0.01v
Updated the chart. CHGR_BMON on good board was 0.07v.
resistors had no sign of damage
below I am posting first broken board voltage in SMC bypass mode, versus working board voltage for comparison
Q5480
PBUSVSENS_EN_L- 0v(broken) vs 0v(working)
PBUSVSENS_EN_L_DIV- 6.09v vs 6.25v
PPBUS_G3H- 12.26v vs 12.55v
PM_SLP_S3_R_L- 3.3v vs 3.3v
PBUS_S0_VSENSE- 12.27v vs 12.57v
Q5490
DCINVSENS_EN_L- 0v vs 0v
DCINVSENS_EN_L_DIV- 8.02v vs 8.28v
PPDCIN_G3H- 16.81v vs 16.62v
DCIN_S5_VSENSE- 16.81v vs 16.62v
DCIN_VSENSE_EN- 3.3v vs 3.3v
only difference I see is overall G3H voltage and PBUS_S0_VSENSE- so maybe bad isl6259 as SMC cannot communicate with it? Or is 12.26v always the G3H voltage in SMC bypass mode?
"is 12.26v always the G3H voltage in SMC bypass mode?"
Yes!
Recheck C5489/99 voltage.
If still low, remove these capacitors and test again.
PBUS_VSENSE and DCIN lines had same resistance to ground as good board
still 1.46v and 2.11v on the two lines even with capacitors removed
r5489, 5488, and r5499/98 all are correct values on broken board
Check again the voltages from these areas.
Posted values do not comply with bottom equation.
SMC_PBUS_VSENSE=PBUS_S0_VSENSExR5489/(R5489+R5488).
Something similar must be accomplished for SMC_DCIN_VSENSE.
I verified every voltage and resistance, and also checked that resistance to ground on the PBUS and DCIN lines were the same as working board.
Is it possible that this is just bad SMC or bad connections below SMC? All the other components are fine.
EDIT: reflowed SMC- board now boots and draws 15w! so likely working!
unfortunately the board did stop working when I tested it again. It kind of tries to boot and spins the fan then stops then tries again. In SMC bypass mode it sometimes gets to a full boot and I hear the chime, but then it dies again. I have never gotten it to show anything on the display either even when it chimes. Sure enough, if I merely heat up the SMC, it boots more consistently- so definitely just a bad SMC. I even took off the SMC, it looked perfect underneath, but same behavior when I put it back on. Voltages are the same as before. So it looks like the voltage/current monitoring portion of the SMC is bad. Replacing it and reballing it is beyond my skill level at the moment.
I am also sunsetting my macbook repair business as I go off to college but I do appreciate the help on all these boards, I have learned a lot from this forum!
