820-3115-B no power
So you have short to ground at pin 21/U7000?
Then change Q7035 and U7000.
I also recommend to change Q7030 at same time.
Be sure R/C7025 are both good.
Do not resolder F7040, until get correct voltage at C7040.
Check all solders/traces for U7000 and surrounding components.
Be sure R7012 is good.
Don't forget the R/C networks connected to pins 5, 7, 8.
Get donor board and replace all components in R/C networks from pins 5, 7, 8.
I suppose you cannot properly test the caps...
