820-3115-B slow, sluggish, ASD
djdblaster
this one works sluggishly. Fans ramp up slowly.
I've removed BIL, Touchpad, Keyboard and HDD cables. Fans still ramp up slowly and Macbook is slow.
I've run ASD without Memory Test cause it takes long and it PASSED all.
No serial number being shown in About this Mac.
PPBUS_G3H is 12.26V.
Why didn't ASD throw out some sensor issue or something like that?
JohnB8812
12.26 means there is an issue around the SMBUS data lines. It will of course run slow and ramp the fans without the trackpad plugged in...First make sure you test with known good parts to make sure that isn't the issue. If PPBUS is 12.26 without anything attached, inspect for corrosion near the SMC. Might even be a good idea to remove the edge bonding and run some flux under it with heat to clear out any corrosion under it.
Post value for SCL/SDA lines of battery bus; diode mode, red probe at ground.
If get more than 1% difference, remove D6950 and test again; BIL removed , of course.
