According with schematic, Bluetooth, TP/KB and IR devices are connected to PCH through an USB HUB; U2700 on page 25.
Check its area for corrosion, rebuild traces if needed, change resistors...
Looks OK, or measured OK?
Did you check traces continuity?
Also check and compare diode mode to ground for all data lines.
All power pins good for U2700?
Corect oscillation at Y2700?
USB_HUB_RESET_L OK?
