820-3115 fan fan spin 3 seconde
aurel476
another board with liquide damage no green light before replaced smc
green light ok after replaced smc
power on for 2 seconde and stop start 2 seconde and stop loop
I have replaced smc twice and same problem pubs_g3h 12,56V and pp3v42_g3h 3,42V and green light OK
possible problem with SPI ?
aurel476
PP3V3_SUS line voltage up 1,5v and decrease a 0,8V loop, possible problem with U7200 (area very clean) ?
PPBUS_S5_HS_OTHER_ISNS 12,59V
P5VS3_EN_L 3,46V stable and P3V3S5_EN_L 0V at Q7221 pin 2 and 5
PP5V_S3 3,3V up and decrease
PP3V3_S5 3,3V up and decrease
Diode mode values are off. Check traces and continuity from U6100 to all termination resistors. R5110 and friends.
aurel476
without U6100 installed on pins of U6100 :
diode mode
1: 1.190v
2: 0.830v
3: 2.288v
4: 0.002v
5: 1.202v
6: 0.881v
7: 0.894v
8: 0.572v
and resistance :
1: 2.561mohm
2: 2.466mohm
3: 29.76kohm
4: 0.001ohm
5: 2.404mohm
6: 2.424mohm
7: 148.4kohm
8: 25.98kohm
I have no idea how you are measuring this or what multimeter you are using, but 1.190 on diode mode makes no sense at all. These lines go straight into the PCH and should have something in the .400 to .700 range. Got a donor board to compare with?
Also have you replaced the clock chip now?
aurel476
for diode mode, black probe GND and red probe to pins of u6100 that's it ?
reverse ,red probe GND and black probe to pins i have diode mode gets :
1: 0,675
2: 0,611
3: 2,240
4: 0,002
5: 0,680
6: 0,681
7: 0,681
8: 0,450
not replaced clock chip , I must replace U2600 ?
i've not donor with PCH present for compare
