820-3115 green light no boot no fan spin ppbus_g3h 4v
gadgetfix
hey all i got a machine it got green light no fan spin but the ppbus_g3h measuring low 4.10v?
pp3v42_g3h is good 3.4v
no sign of water damage
what can cause this?
Did you check on 200 ohms scale?
You should get 2-3 ohms at 17/18 and 20 ohms at 27/28...
If good, post voltages for pins 2, 3, 9, 15, 19, 20.
0R resistors are more useful than one would initially think. They can be used as an additional layer on a board (letting you jump over traces), they can be used to let you enable/disable behaviours or isolate sections during testing / debugging, and they can sometimes be used as desperate-last-hope fuses.
Awesome let us know how it goes! 12.68 seems a little high, so make sure it charges a battery properly and runs off of one.
Just curious why its good to run with battery? should boot with one without right? Anyways I threw it into a working case and no chime, no display. fan still spins. I put under thermal cam and u1800 seems a little hot. its around 60-70c I know the cpu's do get Real hot on these but not sure if this helps in anyway. Would there still be fan spins if CPU was not good?
Yes will run without battery was assuming it might have been fixed. Light on a USB mouse lighting up? CPU Vcore present?
When board really works, VCORE should drop around 0.8V.
Look if U2600 sends out 25MHz at pin9.
Check all traces and resistors around SPI chip U6100.
Also try new BIOS, with clean ME.
Check if R7403 is OK.
"everything look good"
Does this mean visual inspection only?
You must measure all the mentioned resistors.
Post at least what DC level get on pin 9.
