820-3115 - Hissing/ticking noise by the lvds connector
Looks like just a bad fan to me. That noise is an inductor/coil. Usually when you put pressure on the noisy coil the pitch will change. See if you can locate the coil that is making the noise, there are only 3 big coils near the LCD connector.
Find the coil......go over them one by one and put some pressure on them with something sharp/hard, finger won't work.
but fan is working on other machine perfectly.
edit. actually after replacing U6990, Q7030, Q7035. i dont have dim green light anymore. not sure if this is temporary or permanent fixed.
but now, sometime it get a green light and fan doesn't spin and no post.
and sometime green light, fan spin and post.
is it power problem or sensor problem, maybe it want to post but something preventing the fan to spin?
ASD passed all test.
i poked u9330, it got piping hot. i only notice the heat after i pick up the board by usb port.
it has not crack when i looked under microscope. external display are working before poking it.
Thunderbolt circuit. Fuck that shit and rip if off, don't waste time trying to fix thunderbolt the board works fine without.
this cant be causing no fan spin and also i can turn on the board without a fan attached. is this right?
managed to obtain a replacement fan.
i;ve removed both u9330 and u9410. hissing noise is still present. :( maybe i poked u9410 little too hard caused to explode.
still sometime will not switch on, can it be bad smc ?
i;ve removed L9701, L3895, L7770, L7700 L7100, L7630 and noise still present.
have a listen.
lol... just remember i had one of this stethoscope in storage.
i think the noise is coming from Q7070 , Q7630 or Q7085
Let the board auto power on and shut it down with the power switch. Is the noise still present when the board is in this off state?
Yes.I'll remove these 3 components once i get home.
duke, how come forum search doesnt work when i type eg. 820-3115
damn, i'am still stuck
duke, is there a way to turn off a rail. i want to know which rail the noise is coming from.
maybe i should give up :(
You powered it down from battery, this will not exclude U7000 circuit, so I still don't know if the noise comes from there. Power down with AC connected.
