820-3115 mid 2012: no fan
VinceLx
Hello,
I have this board which was water damaged, I restored pp3v3_s5 which was 0V because of a shorted capacitor. Green light is ok, but no fan.
pp3v3_s5=3.3V
pp5v_s3=0V
SMC_RESET_L=3.45V
pm_slp_s3_L=0V
pm_slp_s4_L=0V
pm_slp_s5_L=0V
smc_pm_G2_EN=3.49V
So I understand the board is in deep sleep. How to awake it?
s5_pwrgd=3.43V
p3v3s5_EN_L=0V
p5v3v3_reg_EN=3.47V
SMC_LID=3.45V
SMC_PME_S4_WAKE_L=0.4V (not sure why, I expected 0V in deep sleep)
PP3V3_S4=0.4V
P3V3_S4_EN=0V
SMC_S4_WAKESRC_EN=0V
PM_PWRBTN_L=0.72V
PM_SYSRST_L=0V
PM_RSMRST_L=0V
PM_DSW_PWRGD=3.49V
Any idea where to look?
VinceLx
Here are the values:
PPBUS_G3H=12.61V
PP3V3_SUS=0V (PM_SUS_EN=0V)
SMC_BATLOW_L=3.28V, and PM_SLP_SUS_L=0V
PCH RTC signals:
SYSCLK_CLK32K_RTC: square wave, 1V, around 33kHz
SYSCLK_CLK25M_SB: some spikes
SYSCLK_CLK25M_ENET: idem
SYSCLK_CLK25M_T29: idem
OK, take your time and post PCH's RTC signals.
Look at RTC block inside PCH and you may be able to see them ALL...
VinceLx
Ok, so here they are:
PPVRTC_G3H=3.32V
and
RTC_RESET_L=3.31V
PCH_SRTCRST_L=3.31V
PCH_INTRUDER_L=2.98V
PCH_INTVRMEN_L=1.05V
Then I noticed that R1800 and R1915 were missing... don't ask why
After placing R1800: PCH_INTVRMEN_L=3.2V
After placing R1915: FAN SPINS!! No chime though, I will look into it
Thank you :)
VinceLx
PRAM reset solved the sound issue, boot is ok, internal display ok.
Nevertheless I have no image on an external display.
I ran ASD EFI test with no errors;
I ran ASD OS test with 3 errors linked with wake tests, see attached.
After connecting the external display I see it in Hardware/display, but it does not turn on, the option Mirror displays has no effect. Where to go looking now?
VinceLx
I don't have another VGA thunderbolt adapter, but I tested it good on another Macbook; with HDMI thunderbolt adapter no image either and the display does not even appear in hardware/displays (also tested good on another Macbook). More idea?
Also, how to troubleshot the errors linked with wake tests ?
VinceLx
External display issue solved, it was corrosion around the mini display port...
So only the wake tests problem remain
VinceLx
After solving this display/corrosion issue, the ASD OS test fully passed. Hard to believe given the initial state of the board... Thank you again! You can mark this one as Solved :)
