820-3115 no ppdcin_G3h
Yoel Ren
this came in with various side liquid damaged, i have replaced u7000, q7030 q7035, q7080, but still no ppdcin, even though there's no short..
using fake charger no green light too..
Lab PSU, or fake charger should always deliver =PPDCIN_S5_CHGR.
Did you mean PPBUS_G3H, instead of PPDCIN_G3H?
Yoel Ren
r6995 is bad, replaced, now I have pp16v5 at ppdcin, pp3v42 3.42v
smc_bc_acok 3.4v
adapter_sense is 3.4v up to pin 5 of charging port
sometimes i have green light, and then i replug the port, and its gone, and ppdcin_g3h is back at 1.6v,..
Yoel Ren
when I have full ppdcin, ppbus is at 12.26v, yes i did suspect smc, i will give it a light reflow
dcin board is known good
Incorrect PPBUS_G3H voltage.
Check first SMC_RESET_L.
If good, check voltage and diode mode to ground at SCL/SDA lines of battery bus.
Yoel Ren
but most of time, I either have 0v or low ppdcin..
does smc_reset_l cause low ppdcin ? there's no short on smc_reset_l but i cannot measure thevoltage because i dont even have ppdcin
Thonk if worth to waste time on it then.
Do you get PPBUS_G3H alwaysif power it with lab PSU, or fake charger?
If yes, this denotes an input leakage issue.
