nik1981
I have an 820-3115-B with a intermittent fault.
It always turns on with a charged battery but doesn't always charge the battery.
When it doesn't charge, theres no green or orange light.
When it does charge, it shows orange light as normal.
I've noticed that if its in a charging kind of mood, PPBUS_G3H is 12.42-12.5v
If the charger is removed when its 12.5v, PPBUS_G3H instantly drops to 12.02v and sometimes drops to 11.4v ish
If the charger is plugged back in and PPBUS is above 12v on the battery, PPBUS jumps to 12.5v then drops back to late 11v or early 12v and slowly climbs up to 12.5v
If the charger is plugged back in and PPBUS is low.. like 11.4 or something, it won't light the magsafe but will eventually creep up PPBU to the 12v+ mark and start charging etc
I was thinking SMC issue or Q7055 after reading previous posts but want other opinions before I remove anything.
Second battery tried is known good but doesn't change the behaviour.
Charger is my 85w original
Running off the battery only, PPBUS_G3H is 12.04 in S5.. then when I power on the MacBook. It actually turns on fine but PPBUS drops to 11.4-11.6v instantly. If i then plug in the charger, it won't charge or light up the magsafe until one of two things happen.. either PPBU_G3H creeps up to 11.84-11.85v and then the charger comes on and it jumps to 12.5v or if it doesn't creep up, if I turn off the MacBook, it usually initiates the voltage creep up to 11.84v-11.85v at which point it jumps to 12.5 once it sees the 11.84v
