820-3115 not power on short
Glenn
Sitting with a 820-3115 logic board with liquid damage around u3890 area and j6995.
it have short on PP3V42_G3H (i lift the L6995 and injectt 3,2V) but can't find something that been heatet up (i only get 0.23A on the PSU)
have also replace the u7000
Glenn
I have remove smc, u7000, u5010,u6901, u6990,u7941 a lot off capacitors and resistor i get 2.6 Ohm on pp3v42_g3h.
Glenn
Will try to putt all the missing components back again an see :)
Wasn't L6400?
The board should work without it; no mic, of course...
To solve that, check C6403/05 and U6400.
larossmann
It's the cap under the foam. You won't see/feel it getting hot if you ignore the foam. Get it!!
