820-3115 Not Recognizing Ram With 1 Beep Intervals
jadao
If you have all rails, I2C bus maybe?
Check if the clock and data serial lines shared with SODIMM-A/B are healthy (compare diode mode readings with good board, check pull up resistor value, trace continuity)
I had one liquid damage 2936 or 3115 board, fucked bklt chip LP8850 pulled down one of the SCL/SDA data line and had the one beep no RAM.
Good luck
larossmann
If there is voltage on L7330, then this is some drop that won't get fixed. If you don't have voltage on L7330, then probably a dead U7300. What voltage is on L7330?
supamodz
Hey Louis its about time you got your word in its 1.5v which sounds like its a dead peace of crap because i replaced the u7300 already
