"PP5V_S3 = 0V
PP5V_S0 = 5.05"
That is not possible!
S0 voltage derives from S3.
Unless you have a broken trace to the point where you've checked 5V_S3.
Any history available?
Do you get CPU core voltage?
Tested in SMC bypass mode?
I don’t have a detailed history of this machine — it arrived a long time ago, and I remember working on it briefly before setting it aside. Unfortunately, I don’t recall exactly what was done.
At some point, I replaced the U7200, but it might have come from a donor board and could potentially be faulty — I’m not sure.
Just to clarify, PP5V_S3 is reading 5V as expected. (My mistake somehow yesterday)
Regarding the CPU core voltage, I’m not sure which specific line you’re referring to.
By the way, I tried using a BIOS from another 820-3115 donor board, but I’m not sure if that BIOS was functional — unfortunately, it still didn’t work.
I do have a CH341 programmer, but I’m not experienced with BIOS flashing or cleaning the ME region. Do you think I should give that a try?
