820-3115 PP5V_S3: 0v (Pulsing) only green light on charger
No-Clean
Board came in with a short on PP5V_S3 U7200, replaced it 2 times just in case, short gone and now board makes it to PP5V_S3 with 0V and about 5 seconds later it pulses to 5V, most other rails also pulse, board is pretty clean otherwise.
SMC, U7400, U6100 (With Clean BIOS) replaced but same thing.
R7402 and R7403 good and surrounding components of U7400 look clean.
SMC Bypass same thing.
ALL_SYS_PWRGD 0V not pulsing
AVREF_SMC 3.3V
PPBUS_G3H: 12.53v
PP3V42_G3H: 3.4v
PP5V_S5: 4.95v
PP5V_SUS: 4.95v
PP5V_S3: 0v
PP3V3_S5: 3.3v
PP3V3_SUS: 3.3v
PP3V3_S4: 0v
PP1V8_S0: 0v
Remove R7963-6, one by one.
Check when appears the pulse on ALL_SYS_PWRGD.
Maintain R7967 in place, of course.
Monitor U7400's voltages: 19/29, 46, 47, 1, 49.
Can you detect any pulse on them?
Did you check all SPI Bus Series Termination resistors and their traces?
No-Clean
U7400's voltages:
19/29 Pulses
46 Pulses
47 Pulses
1 Steady 12.3V
49 Does not exist
48 Steady 12.3V but reboots every few seconds
You've said 12.3V on PPBUS_G3H in first post; later 12.3V.
What is actual voltage?
12.3V may denote a SMC issue.
However you shoulkd get at least a pulse on CPU core; as same time with ALL_SYS_PWRGD.
PCH, or CPU may have problerms.
There was possibly an overvoltage on 5V_S3 power rail.
Check any other power rail derived from it.
No-Clean
PPBUS_G3H is 12.6V
But pin 1 of U7400 (CPUIMVP_TONB) is 12.3V R7403 is fine.
ALL_SYS_PWRGD does pulse, but VCORE does not.
Checked all other rails on page 8 all okay.
Thanks!
