This old board was coroded and had many issues to name a few:
3 bad sensors due to bad divider resistor and or traces and or sensor itself.
3 shorts firewire thunderbolt and IR chip
Bad backlight circuit with maximum of issue, fuse, sensing resistor, traces, driver chip enabler circuit
Bad charging circuit
CPU TON A and B
The repair went smooth, and last thing I tried was to test if IO0R sensor fault went away.
In ASD EFI the sensor section is sometimes missing.
When the sensor section decide to appear an I run the test all values are -124 Volts, Celsius, Amps or whatever value we are testing.
I am just about to abandon this board.
Any idea to check? something common must be related to smc...
Logicboard runs well...
Thanks
CPU TON A and B
Thanks
