820-3115 - Short on PPBUS_G3H ?
kronos23
Hi Guys.
Working on a 820-3115 with no power no green light. Liquid damaged in the U7000 and Q5480 area.
I replaced both of those components and surrounding caps/resistors.
Found a short on PPBUS_G3H that I tracked down to CHGR_PHASE on Q7035, when I removed it the short went away. I also replaced Q7030 & Q7080 for good measure.
Connected adapter and got green light but PPBUS_G3H was low 6.34V. It slowly went down to 0V and the short returned.
I replaced U7000 again to rule out bad placement. Same symptoms.
Here is what I am noticing now....if I test for a short at CHGR_PHASE on Q7035 the short shows for a few seconds then is gone. I also get these results if I test PPBUS_G3H on R5481 as well .It is like the short is "moving" from one end of the circuit to the other.
PPBUS_G3H shows a short then CHGR_PHASE doesn't and vice versa.
I am stumped. Any suggestions ?
Uhm this is a PPBUS short and has nothing to do with the sponge cap.....
You need to replace U7000, Q7035/30 all together at once. But it does sound like the gate of Q7035/30 has no continuity to U7000 so you can "activate" the FET with your multimeter and cause a short because you enabled the FET by measuring on the gate. I suspect corroded trace to U7000.
kronos23
Found R7005 to be blown. Replaced it and the board powered on and then died with in 10 seconds. Green light faded away and PPBUS_G3H short returned until I removed Q7035 again. Something on the circuit is blowing Q7035 and creating a short but I cant figure out what it is.
I can only advice to check all traces and resistors around U7000. Traces to Q7030/35 are still suspect are traces to C7025. U7000 will probably be dead again and both FETs too.
