820-3115 won’t run out of battery
Did you try other known good battery?
Does it charge battery?
Post PPBUS_G3H volatge w/ and w/o battery connected.
Please post more relevant information when you ask for help...
suzukigsxr1000r
I tried new battery it is not working with it .
yes it charging the battery and percentage goes up fine but once disconnect the charger it is die .
the PPBUS_G3H with battery connected is 12.61 v without
battery is 12.60 v .
With battery you should get lower voltage, increasing when charging it.
PPBUS_G3H goes back to normal value once battery is fully charged
Did you check with 100% battery charged?
Machine does even try to start on battery alone?
Any way to test these batteries with other board?
Post PPBUS_G3H voltage on battery alone.
Also run ASD with battery connected.
suzukigsxr1000r
Sorry I measured first time with charger .
battey alone now is 95% charged , the voltage on PPBUS with battery only is 12.39 .
these batteries works fine with other boards .
when battery alone connected it is try to start and the fan spin second the stop .
suzukigsxr1000r
No Title
