820-3208 No LCDBKLT
AppleTech
820-3208 (no Back Light) No Liquid Damage.
0 Volts on J9000 (Pins 3,4)
0 Volts on C9713
0 Volts on R0910
Q9706
8.4V on Pin (4) 7.9 on Pin (3)
0 Volts on 1,2,5,6
any help is greatly appreciated
You didn't tell us if it has image...
USB mouse works at least?
Do you get voltage at pins 18/19 of J9000?
Also check LCD_BKLT_EN and BKLT_PLT_RST_L.
replaced Screen at the beginning which was a waste of time. should've checked the Voltage first.
MBA fully functional on external display.
Yes there is DATA (Dark Image)
Fuse> assuming you are talking about F9700 (8.4V Both sides)
i'll check J9000 (P18/19)
If you get image means display is correctly recognized, so there is voltage; no need to check it.
Check above mentioned signals.
Board was picked by customer (He says the Genius Bar told him they would look at it) loool, made me laugh i packed his laptop in a heartbeat. we'll see when he comes back.,
