i don't understand for the video, i see the video.
we can see when i plug the power cord, the mac start and make dong continu.
can you explain SMC bypass?
ok i don't understand for the video.
when i start in SMC bypass, i have fan in full speed and same problem dong in loop.
have you an idea?
the BIOS is clean?
i test your file but same problem (normal and SMC bypass), with new memory, idem.
my customer say, the mac mini boot before change the hard drive well, but on the hard drive was install hackintosh with efi partition, can make a problem on the board?
i work already without HDD, just fan and led front panel. I try to change the power supply, without led front panel, always same.
I check component on the board without find anything, i haven't schematic, i can't check the supply on the board.
