820-3330-B Not powering On
techgeeksna
Good Day , ive got a A1268 820-3330-B board here. The computer was working fine and the next morning refused to turn on. The green led on charger lights up for about a minute then goes off. The computer wont switch on from power or from battery.
so far ive measured the following.
PPDCIN_G3H - 16.2V
PPBUS_G3H - 12.6V
could anyone please point me in the right direction.
P.S Yes im using 85w charger and yes its the original charger.
thanks i will check that, im in a completely different time zone, which means when your awake im asleep and vice versa. Do you perhaps have any other ideas i can try if the trace happens to be good? im currently using another board that does power on to test different points and i also get the low voltage ACOK at pin 14 of ISL. 2.3v/2.4v.
Like i mentioned in my initial posting the computer was working perfectly fine and just died the next morning. No signs of liquid damage and no physical damage either.
Good Day, a short update. pin 14 and pin 1 of r5393 are same voltage and the trace is good. So im still stuck with a board with no green or orange LED.
