This 820-3332-A board runs fine with the charger connected, but won't run on battery.
When it's booted the OS sees the battery (says 17% charged), but won't charge the battery.
There was liquid damage around the battery connector. When the system boots there is 12.5V on J6950 (PPVBAT_G3H_CONN / GND), both with and without the battery connected. This voltage goes away after a couple of seconds. Both SDA and SCL lines are 3.4V, SYS_DETECT_L = 0.2V. Measured with diode mode on SDA/SCL lines, both are 0.402V.
The battery while disconnected measures ~2V on the PPVBAT_G3H_CONN / GND connections on the connector, but ~11V on the actual battery connection (other side of the little circuit board connected to the battery). Not sure is this is normal behaviour of the little (charge protection?) circuit board connected to the battery.
Is this just a dead battery (well, broken charging protection PCB connected to the battery), or is there more to it? Currently I don't have a replacement battery to test with. Something tells me it's something else, because of the liquid damage around the battery connector. There was a little bit liquid damage on the battery connector itsself, but most around U6990. Replaced U6990 because of corrosion under it, but didn't change anything. ISL looks fine, no liquid damage around it.
